I need to append line feed {LF} characters to my carriage returns {CR} in my M4A files so they display properly in my media player (as {CR}{LF}) but MP3Tag seems to scrub them automatically (a test on an MP3 worked fine) Is there a way to disable his behavior?
What have you tried in which field?
Did you have a look at the help on regular expressions?
(Replace with Regular Expression – Mp3tag Documentation)
especially \n and \r?
I have made an Action to "Replace with regular expression":
Field:
UNSYNCEDLYRICS
Regular expression:
[\r]+
Replace matches with:
\r\n
I have also tested it with replacing \r's with 0's (worked OK) and just \n's (removed the \r's and left nothing behind).
