I just did a fresh install of MP3Tag v2.32a after a full Windows Update including .Net with SP1. When I start the MP3Tag program I get the temporary pause, but then no program windows shows up. If I CTRL-ALT-DEL I can see that the program has started, but I cannot get to the program window. I am running WinXP Pro and Home (2 computers) and I have the same problem on BOTH machines. Any ideas on how to fix this? Thanks!
Please look first at this post, maybe it the same problem.
Regards
nickless
Nickless,
That fixed the problem! Thank you very much for the reply. I can now happily use MP3Tag again. ![]()
