Mp3tag v2.36a - Failure of launch with directory
#1
Is the mp3tag command-line interface documented anywhere?
Else, an anyone tell me how to fix the following command line:
"C:\Program Files\Mp3tag\Mp3tag.exe" "C:\dir"
so that it loads the dir? As it stands, it fails to do so if the program is already running.
Thanks.
#2
"C:\Program Files\Mp3tag\Mp3tag.exe" /fp:"C:\dir"
#3
Thanks but that makes no difference.
e.g.
1 "D:\Program Files\mp3tag\mp3tag.exe" /fp:"D:\Audio\mp3_ To Music Lib\specials"
2 Create new file in that dir
3 "D:\Program Files\mp3tag\mp3tag.exe" /fp:"D:\Audio\mp3_ To Music Lib\specials"
4 See that mp3tag screen does not refresh - new file is not displayed.
Chris
#4
Hi Chris,
this will work with the next release!
Cheers,
Florian
#5
Thanks. I strongly suggest that his behaviour be the /default/. I.e. that /fp be not required.
Also, it would be good for the docs to inclulde the list of switches such as /fp .
#6
It does - thanks!
Note: this improvement is missing from the change list (Mp3tag Development Build Status)
