I hv just download v2.37a. I am facing a problem now as I cant use it with the software Mega mp3 splitter anymore. Somehow, all the titles I used to save them using Chinese characters cannot be read by the splitter. It shows only questions marks (????).mp3 instead of the title name. If I changed the titles to english characters, I dont face any problem with the splitter.
Would appreciate if anyone can help me solved this problem.
nope, both ways, it cant read by the software mega mp3 splitter. It was working well until I did a virus scan and deleted some files and tats it, mega mp3 splitter can never reads the song tilte in chinese ever again
It seems the program cannot open unicode filenames.
If you have a chinese filename, you can try this in Mp3tag:
Select the file(s), press Alt+1 and enter $ansi(%_filename%) press OK.
I don't know if this helps/changes anything.
Oh, well if the language is english then $ansi() cannot work for chinese words.
I see no possibility now to make the program accept these filenames and I also wonder a bit why it worked in the first place.
