I've just released Mp3tag v2.41c Development Build!
It's a Beta version and has some important internal changes. The most important for all users with excessive use of cover art are major improvements regarding memory consumption.
Other highlights are support for iTunes-specific TV/video tags, support for drag'n'drop of cover art from Mp3tag, and the possibility to navigate back during tagging from web sources.
It would be great if you find time to test this build and report issues in the Bug Reports forum. Mp3tag v2.42 is scheduled for late October.
a lot of thanks, Florian. your app is very helpful to me.
but there is one more uncomfortable thing in new builds with unsynclyric: when i edit this part of tags, i often press Enter and then window closes. i know that i can use Ctrl+Enter, but its uncomfortable, cause i permanently forget about it.
could you add an option to choose between Enter and Ctrl+Enter for new line when editing any of tag?
Your Beta 2.41c works great. The one thing that the program is still missing is a field for Disc. You have a track field now where you can name the current track and the total tracks (1/10) etc.; is the next build 2_42 going to include a field for Disc (1/2) etc.?
