I've just released Mp3tag v2.47!
Changes of the new version include:
Actions menu
The actions feature which was well hidden under the converter menu now has a dedicated top-level menu where all action groups are accessible via menu items.
Tag fields renamed
With this release some of the tag fields that are used for format strings, actions, columns, exports, and filters are renamed to have more accessible and intuitive names. This also means that all parts of Mp3tag where you have used the old names have to be updated. We know that this is an invasive change but think that it was a step necessary to keep it everything maintainable and understandable for new users of the program. Please see Tag fields in Mp3tag for an updated list.
Amazon
Amazon has limited access to their web service to 2000 requests per hour. That means that you might get an occassional error 503 when using the Amazon tag source. However, the limit is reset each hour so you can try again later if it is not working for you.
As usual, there is more to discover in the Changelog.
You can download the new version from
http://mp3tag.de/en/download.html
Thanks to all who tested the Development Builds and gave feedback on the forums!
Enjoy
Kind regards,
Florian
