With this version, I’ve taken a leap and completely rewrote the Tag Panel layout. Especially when docked horizontally, the fields now flow naturally and the cover art window resizes based on the panel size. I really like it and I hope you do too
All fields are now configurable (including the default fields) and can have one of four different sizes (normal, smaller, small and multiline). I’ve added an option to enable/disable fields (also available via right-click on the Tag Panel) and ways of loading and saving Tag Panel configurations.
As if this was not already enough, I’ve added support for long file paths (> 260 characters). This was a change I was hesitant to make for a long time, as it affects many, many parts of Mp3tag.
I’ve also updated the Discogs and MusicBrainz tag sources, which stopped working due to changes on their servers. You can review the many other changes in the changelog.
Großes Lob für das Update des Tag Panels!
Big kudos for redsigning the Tag Panel! It resolved quite some pain that I didn't even dare to ask being improved:slight_smile:
Especially shrinking small fields (like th compilation flag, or simple date fileds) now allows having more than one in a row, significantly saving vertical screen real estate.
Great Job, keep it up Florian!
