Mp3tag v3.28 released
I've just released Mp3tag v3.28 and wanted to outline some of the new features and changes:
Large Toolbar Icons
Depending on the screen resolution, the Windows DPI settings, and/or the individual strength of eyesight, the toolbar icons could be perceived as too small and as difficult to identify and distinguish. I've added support for scaling toolbar icons up to 200%. You can find the new configuration setting at File → Options → Appearance.
Replace Cover
If you want to replace the existing embedded album cover, it involved a couple of steps (removing old, and selecting new). If the file had multiple covers and you wanted to replace a cover, even more steps were involved: in addition, the existing covers needed to be exported and re-added. This is a thing of the past, and the currently displayed cover can now easily be replaced via the Edit → Cover → Replace Cover function (also available via the right-click contextual menu on the cover window).
Bugfixes
And there is the usual bunch of fixes and smaller improvements, which always give the feeling that this version, yes — this current one, might be the best version of Mp3tag yet.
Download the new version
https://www.mp3tag.de/en/download.html
Support my work as an Indie Developer
https://www.mp3tag.de/en/donations.html
Enjoy and take care
— Florian
