Mp3tag v3.36 released
I've just released Mp3tag v3.36 and wanted to outline some of the new features and changes.
Improvements to Tag Sources
I've improved the performance of executing Tag Sources, especially those with many conditional expressions. I've also moved querying and execution to be performed in the background, so that the user interface is no longer blocked by long-running queries. In the process, I've changed a lot of code, ancient code even, and I'm happy with the result.
I've also added a button to preview the full cover in the Tag Sources query results dialog (if provided by the Tag Source), which gives a nice way of checking the artwork directly from the results list.
Custom Field Values Independent of Tag Panel Fields
The problem with Custom Field Values so far was that they were tied to Tag Panel fields. That is, if you removed the field, the custom values were gone too. Recent versions also made those values available in other places, e.g., when editing fields in place in the File List or via Extended Tags. I've now consolidated the management into a new configuration page at Options → Field Values.
Export to Multiple Output Files
Similar to the Playlist Generator, it's now possible to export to multiple output files by grouping input files according to a user-defined format string. This way, each group is exported separately. It's one of the features that was repeatedly asked for and it took some time for me to come up with a good solution, especially one that doesn't add even more commands to the export templating language.
Bugfixes and Internal Changes
As always, this new version includes bug fixes and many other improvements. For example, I finally found an issue that produced a crash when writing tags to malformed or truncated FLAC files. If you're curious, the changelog has the complete list.
:rocket: Download the new version
https://www.mp3tag.de/en/download.html
:orange_heart: Support my work as an Indie Developer
https://www.mp3tag.de/en/donations.html
Thank you for reading, and for your interest and support.
Enjoy and take care
— Florian
I've just released Mp3tag v3.36.1 which fixes a regression when adding covers to multiple files with varying covers that was introduced during the v3.36 beta cycle.
