Why are you still using iTunes for tagging after all what we did for you in this topic? ![]()
I've edited ALBUMARTISTSORT in Mp3tag and it worked without problems.
Yes, you're absolutley right! I'm sorry, why did I use iTunes? ![]()
I used iTunes for too many years and got used to it. But there is really no reason any more. I don't have any Apple device. And since iTunes messed up my library so much, I'm surely going away from iTunes and won't let it manage and sync my music any more.
This is great, I will of course use MP3Tag now ![]()
I'll have to look a little more into it. Maybe I can even solve this automatically for all my files with your tool through an RegEx-Expression.
Thanks again for looking into all of this and helping out so much!
Here is a post from the HowTos how to copy one tag field into another:
Even if you have any iDevices and need to keep using iTunes, make sure these preferences in the Advanced tab are both UNchecked to prevent iTunes from modifying or moving any of your files. You can still add new ones by dragging them to the iTunes window or using File>Add File or File>Add Folder menus, but now they will stay where you want them, even on separate drives if necessary.
Perfect, thank you very much guys! I see this is a great tool! I'm going to study the HowTo-Section a little more ![]()
