I have used some great exports created by Dano and Milka for my MP3's. Now I have many folders of Mp3's listed by Artistist then inside by Album. They all have an individual web page for each album.
I would like to know now if there is a Multi-folder Export available to generate an HTML Index page of all my music folders? Or does any one know of a application that will create an Index? I looked on Google and the only thing I came up with was Easy Index Generator (It's sort of like a site map generator). But the application isnt reliable and the results cannot be duplicated every time that I run and generate the Index.
Preferably I would like to create a web page Index that would show thumbnails like a program like Arles Image Web Page Creator does. I would like it to show each Artist then use a thumbnail of the album cover for each Album or CD I have inside the Artist folder.
The problem I have with Arles Image Web Page Creator is that it snags the first picture it comes across and I cannot automate and select the file I would like, which is cover.jpg unless I do this manually for every folder. Needless to say this would take hours or days to complete manually. So I am after something that would automate the process.
I tried using html_milka_album_list found here:
But I get an error: $filename() is missing its parameter list
Ok I was able to edit the export to get rid of the error. What I did was remove the $replace after $filename.
I may be able to use this export after I modify it a bit
