Multi-line field options
New to using mp3tag, so please forgive me if this is obvious but I cannot find a way to make any of the tag panel fields multi-line. Like for lyrics I would like to have more than one line. I can see that this exists for the windows versions but maybe it is not a feature available on the Mac version yet? Or is it because the field is a list? How do I change this? Furthermore, is there a way to have multiple tag panels that I can switch to so that I could see all the lyrics at once instead of having to scroll down in a small field or box?
Thanks!
It's not obvious, and even if, perfectly fine to ask!
All of what you've written are feature suggestions for Mp3tag for Mac. Multi-line fields are on my list, multiple tag panels is not planned for the near future.
Hey,
Thanks for the super quick reply! Good to know that multi-line fields are on your list. The multiple tag panels would be cool, but probably not necessary since there is a popup window for expanded tags. Maybe I should suggest a new window for displaying lyrics that pops up when you click into the lyrics field instead? That way you don't have a lyrics box taking up room in the tag panel. Just a thought. I do a lot of formatting and correcting lyrics. Really enjoying the program so far!
I've just released Mp3tag for Mac v1.7 with support for multiline fields on the Tag Panel (e.g., for adding lyrics or podcast descriptions) in addition to standard text fields and checkbox fields.
