The new multiline feature looks good. I would find it useful for comments, although I see no way to do this?
Anyone know?
Thanks for any info.
Anyone know?
Currently not possible.
I know ![]()
Close Mp3Tag and add the following to the file "\Application Data\Mp3tag\data\usrfields.ini":
[#0]
value=COMMENT
name=Multiline-Comment
multiline=1
You should change [#0] to a not yet used number if you already added other fields.
Works perfectly in Mp3Tag v2.44h (it overrides whatever is written into the normal comment field), although Florian probably didn't wanted that... ![]()
Thank you, Florian! ![]()
