Hello:
I greatly enjoy using MP3Tag, but I do have one question I would like some help with. I see there is a "9" option for Multiline Rows, but is there a way to increase the amount of rows a multiline field can handle?
Thanks
Hello:
Thanks
This number refers to the display in the tag panel. Longer text then leads to scrollbars.
It does not limit the amount of data that can be stored in a tag field - that depends on the tag version.
Makes sense to me. Thanks!
