Why is it that MP3Tag defines several genres as different TCON tags?
ID3v2.3 states clearly that several genres should be defined into a unique TCON tag, starting the field definition with a '(', and separating each genre with parenthesis, such as '(Pop)(Rock)'...
What i mentioned is what ID3 states in rev. 2.3. And, "from time to time", foobar2000 does keep it (it depends on how "non-conformantly" the ID3 tags were written).
Making MP3Tag an strict ID3-compliant tagger would be a big step for human race. Perhaps others would try to follow
I'm not quite sure what you're saying. You mean that when foobar is set to "ID3v2 writer compatibilty mode" (i.e. writing ID3v2.3 tags instead of -2.4) it writes TCON frame in a way specified in official guideline - ID3v2.3.0? I doubt it.
