I don't know if it's okay to post this here. Sorry, just in case.
I need to know if it is possible to use, at least, the following fields in a .wav:
-albumartist
-artists
-musicbrainz_artistid
-musicbrainz_albumartistid
For .flac files I can enabled (and it works), from Tools>Extras>Tag-Panel (eg: adding MUSICBRAINZ_ALBUMID). But for .mp3 and .wav I can't
It is possible to do? Other names fields correspond for .wav or .mp3?
What I care is .wav.
PLEASE, I need that help.
THANKS.-
I found this list of WAV info chunks:
http://www.robotplanet.dk/audio/wav_meta_data/
It does not look like there is a field for the album id (just like there is none for composer).
The way to modify the tag panel is described in the help https://docs.mp3tag.de/customization/tag-panel
I put the fields for a mp3 (eg: MUSICBRAINZ ARTIST ID instead musicbrainz_artistid). I don't know if it works, but at least the program that I use sorted the album artist in right way.
The usual field for sorting the ALBUMARTIST is ALBUMARTIST.
You see the name of a field in the extended tags dialogue (alt-t).
If you want to refer to the contents, enclose the name in %, e.g. %albumartist%.
