MusicBrainz lookup in Mp3tag
Hey there, I just came across http://www.musicbrainz.org/ , and it's great I think. However, their tagger is limited to looking up from and tagging from the musicbrainz database :flushed: , which makes it very limited :frowning: .
There is an SDK available, and I personally think it'd be great :w00t: if Mp3tag supported MusicBrainz lookup. It has a lot of good stuff!
Thanks
PS: I'd really like optional support for a composer tag too, and keep up the good work! You're doing great so far!
nalixl,
I'll have a look at MusicBrainz and the SDK.
Try View, Tags....
Best regards,
~ Florian
