Every column in Mp3tag can be sorted ascending or descending. Just click again on the column header where you see your content "backwards".
You see the current sort direction with the small "arrow up":
or "arrow down":
or "arrow down":
LyricsLover I just did this, it's worse, it's very mixed...
In my computer ^ Filename
and Mp3tag ^ Filename...
AND I have to take my songs with my mouse from bottom to top ?????
ok I saw...
My question LyricsLover and Ohrenkino,
Choose ^Windows Filename and choose Filename^Mp3tag
Choose your songs from top to bottom and bottom to top
What result do you get???
The same sort order.
Assuming your "Filename" column definitions looks like that:
Excellent LyricLovers, I hadn't thought of that, I'm going to go see...
Repeated clicks on the column header go through the various ways of sorting:
See which order is best for you.
LyricsLover & ohrenkino
Here are the results :
Value: %_filename_ext%
Field: %_filename_ext%
Sort by: %_filename%
Digital: √
No uncheck/deselect Digital (Numeric in your language) and try it again ![]()
See also here:
Which was something to check 19 posts ago.
We blow the trumpet
It works Oh Yeah
What is Numeric???
From the help:
The Numeric checkbox affects the sorting of the column and determines if the column contents are aligned left or right.
This numeric was driving me crazy...
Especially, if all your filenames looks like
M0006.mp3
M0007.mp3
M0008.mp3
which is NOT numeric (they start with a letter, not a digit).
This is the definition for TRACK - for Filename it should not have the little blue check mark in the box "Numeric"
It's true in IT, it's like that...
Many thanks ohrekinom & Lyrics Lover...
for spending this time with me, to help me, it was driving me crazy, this story, I'm going to sleep well...
A+ Guy's
Oh Yeah...I will remember it for a long time...
For me it's good night friends and good morning for you...
3:00am Montreal
9:00am Germany
Goodbye see you soon ![]()
