Is there any way, within the application itself, to increase the size of the display and the text within it without affecting the appearance of other applications?
I'm finding it harder and harder to use mp3tag alongside other programs as I find it increasingly tedious and uncomfortable to use. It seems like it ought to be easy enough just to scale the image so that I don't have to squint or run to another room to find a magnifying glass to hold up against the screen.
I've tried most if not all of the available settings in Windows 10, but of course these affect ALL of the other applications as well, and yet none seem to make it easier to use mp3tag.
I have reading glasses supposedly optimized for use with computers, and they help a little bit, but I'd be more comfortable using the scroll bars to move around the screen.
Thanks for any suggestions on this topic.
D2B ...
By the way, if you've read this far, please consider becoming a "perennial" donor. Mp3tag is indispensableāthere's no substitute for it.
