My .mp3 files no longer have embedded images
I noticed that many of my .mp3 files no longer have embedded images.
I know they once had them because the folders all have the Folder.jpg files that WMP generates.
So my question is: Can I use MP3Tag to somehow copy the Folder.jpg files into the .mp3 files?
But not one at a time since I have very many files to fix.
Try an action of the type "Import cover from file"
Set as filename: folder.jpg
Sounds great but I don't know how to how what the document says. Can you give me a quick how to do this?
See the FAQs:
Thank you, I'll try now.
However, you should bear in mind that folder.jpgs created by Windows Media Player from the embedded cover files only have a small resolution of 200x200 pixels and are not identical to the previously embedded pictures, which may have had a higher resolution.
@poster is right - and the import would overwrite existing and perhaps better pictures.
So: to treat only files that really have no embedded picture use a filter:
%_covers% MISSING
Disable and enable this filter after you have imported the pictures to see how many files are still without embedded picture - as there was no file called folder.jpg in the file's folder.
Are you sure these cover images were actually embedded? A quick check of a few of the folder.jpg files will help to confirm. If they are larger than 200x200 then they probably weren't created by WMP.
I am curious to understand how the embedded images would have been stripped out. Are all other metadata fields intact like Title, Album, Artist, etc.?
I have no idea how or when
. Yes
I doubt that anyone who has not looked over your shoulder all the time will be able to say anything about this.
Much more interesting in this forum would be:
Have you succeeded to embed the existing pictures?
Did you check the result with the filter?
Yes, I did as you said.
Mp3Diag tells me I have progressive jpg files inbedded.
These are not from the imbedded Folder.jpg. files
I did not have a Folder.jpg for a couple of CDs so I downloaded images.
Do you know the file extension for progressive jpg files?
I'll look for different images to replace the progressive ones.
jpg? jpeg?
They usually differ only internally. You could modify them and transform them to the png format which does not not know progressiveness.
And just for the record: progressive jpgs have a valid format - it is only some players that cannot cope with them.
