- Remove IDv1 with actions.
- Remove fields with actions (unsyncedlyrics is not deleted completely with the replace funtion "", it allways shows eng||)
- A Preview!!... Renaming or tagging 500 files takes a long time even with my quadcore. And if the results have mistakes... then I have to click undo... and rename them all again.
- Double click to access to Extended tags dialog, instead of play the file.
- A better manage of Actions Groups.
- Descriptions for the Actions (instead of use (?#comment)). It's not clean.
- Possibility to activate-deactivate each Action (inside Action Groups).
- More support to Regexp Expresions.
Dear SKsk,
I have the same proposition of you, for me it is either a preview or a resume of the
changed files (see my suggestion right under yours). Until now no answer of mptag !
Greetz.
Musiclover.
