Name change case help
The filename of a music file, the title name written in capital letters.
AHMET-BEN SENİ ÇOK SEVDİM.mp3 BEN SENİ ÇOK SEVDİM
Ahmet-Ben Seni Çok Sevdim.mp3 Ben Seni Çok Sevdim
Is it possible to change the capital letters so that only the beginning of the words are capitalized?
See the HowTos:
Thank you, could you enter an example code? For example, AHMET to make this Ahmet.
If you look at the description in the linked post - what have you done to try it?
Could you post a screenshot?
It is much easier to continue from where you have got than for me to repeat the already existing description as it shows already what to do.
It would help to see where you get stuck.
But perhaps a look at the documentation helps:
Hello, when the mp3 tag is opened, how can we make the files like the 1st picture as in the 2nd picture, thank you
Create an action group with 2 actions of the type "Case conversion"
  1. for field TITLE mode "mixed case"
  2. for field _FILENAME mode "mixed case"
I couldn't find where to paste these codes and I couldn't do it.
Did you have a look at the documentation? This should reveal that there is not really code to paste but options to be selected from dropdown lists.
Do the following:
  • Load the files.
  • Select the files.
  • Select Actions (quick)> Case conversion
  • In the opening dialogue select as field: TITLE
  • Select as mode: mixed case
  • Make sure that at least the space character is entered in "Words begin from/ater ay of:"
grafik
  • Start the action with OK.
  • see whether the cases in TITLE have changed.
Do the same for the field _FILENAME
Thank you very much my friend, you are very kind, best regards. In some songs, their names change due to the font or the player. Is it possible to prevent this in the mp3 tag?
If you see something in common for the exceptional files, then apply a filter.
But as before: it would help a lot if you could show us what you tried, what the result should be and what it actually was.
Without any details you get only very general suggestions.
