Hi.
For a full understanding of what the Actions do, please read the Readme file.
I'm removing all that text from here to make this post shorter and up to the point.
Changes in Last version only:
Version: 3.1 [2014-09-08]
FIX:
I found a "buggy" behaviour from Mp3Tag "Guess Values" Type of Action.
It will create blank fields if they are empty. The "Format" Type of Action does not have this wrong behaviour.
Unfortunately I only discovered this after posting the v3.0 of this Action.
I didn't have much time to test it since I was about to loose my Internet connection for a few days. I'm sorry.
But that problem is solved in this version!
Bug report thread:
/t/16093/1 -
FIX:
Another inconsistent behaviour when updating multi-value fields with only one value. In some cases, it will remove all other values after the second.
This problem affected the Action only in what I call the Preferences fields (Genre, Mood, Occasion, Keywords), so it was not critical, but still annoying.
I found a turnaround to this problem and therefore it's fixed on this version.
Bug report thread:
Wrong Import with Multi-Value Field -
CHANGE:
The major rework on how the Actions are developed was now extended to the "2. Natural MixedLower Case".
Now only one line of code needs to be updated in order to update "minor" words, for each language.
It's also much easier for anyone to change it in order to suite their own needs. -
ADD:
Added a new version: "2. Natural MixedLower Case [ENG+FR] (v3.1) (-Album)".
This will not lowercase minor words in the Tags: ALBUM and ORIGALBUM.
I noticed that in some Album's names the Artists prefer to have the first letter always uppercased,
even if they are "minor" words. (e.g. "This Is A Test Case" instead of "This Is a Test Case").
This action gives that flexibility.
If you want to create such a variation to your own language (DE, ES, IT, PT), all you have to do is edit the Action and remove the lines corresponding to the "Format" command to those fields, which now are easily recognisable.
For the remaining changes, please read the changelog. There were lots of them in v3.0
All fixes from posts 10-12 were already attended since v3.0.
I would like to thank users from this thread, as well as DetLevD and Ohrenkino for their indirect help with all the answers they provide in the forums.
Good tagging!
NaturalCase_v3.1_Actions_Columns_.zip (7.75 KB)
Test_Library_v3.1.zip (153 KB)
Readme_Changelog_v3.1.zip (10.3 KB)
