As per topic, I'm looking for a script that renames .CUE and .LOG files using the tags from an album.
My music collection is so big it would take forever to manually rename these files.
I want to use the naming scheme: "00 - %album%.CUE" & "00 - %album%.LOG".
Does anyone have something that can do this?
Regards,
Phixion
poster
2
If your cue and log-files are situated in separate album-folders that have the name of the album-tag you can
Add *.cue and *.log to the list of restricted files in tools\options\tags
Filter the listed files by enterng "%_extension% IS log OR %_extension% IS cue".
Mark the now shown log and cue-files in the list-view.
Use the converter "Tag-Filename" and as a format string enter %_directory%
Many thanks for this, great idea.
I guess there is a way of getting just the album info out of the directory, as I originally wanted to name them like so:
00 - %album%
But this method at least gives me something to work with, thanks again.
poster
4
If the directoty is always named like this (5 characters before the album-name) you can take
$cutleft(%_directory,5)
as format string.
