Need help - I am new to mp3tag. Using 2.57 version.
I have many files that have characters with the pattern as '(*)'. By * I meant non space characters. I want to remove the text pattern from from the filename.
Tried two ways but both remained unsuccessful:-
Convert filename to filename -
Old pattern: %1
New pattern: $left(%1,$strchr(%1%,'('))
Please supply a real filename and not just a "pattern".
E.g.
If I had a filename like
My ex(ploded) girlfriend.mp3
I could get rid of the brackets with the converter filename - Filename and the mask:
Source: %1(%2)%3
Target: %1%2%3
Thank you very much. Your reply helped and works!!. I tried it earlier but didn't work. After your reply I tried again only on one file with the matching pattern and it worked.
I think, I figured out the mistake I was making. I selected a bunch of files and was trying to apply the converter. It works only when files have matching pattern. It is my bad, that I was expecting that it will find that matching pattern in all the selected files and then converted whichever it finds.
