I would like to request evaluation of my code that I wrote for a column
$if(%ALBUM%, $if($strchr(%ALBUM%,|)'+ OK +','- DISCS'),'')
And here is what it is suppose to do: search for the sign >>|<< in ALBUM tag field and display >>+ OK +<< if it is there or display >>- DISCS<< if it is not there; and if the whole ALBUM tag field is simply empty, then display nothing
I did look at what I already have and use- and thus found some other codes with which I tempered a bit. And then I tried finding what I lacked at https://docs.mp3tag.de/scripting
And only then did I went to the forum, presenting with what I came up to believe was the closest that I could get on my own
Do not think I do not appreciate the time that is required to help the likes of me on this forum or that I do not try to learn something useful also outside the Mp3tag when spending so much time with it
