I now as a result have 2 new issues. I swear Ill catch on to this eventually.
when faced with files that are NOT VBR AND are NOT the same bitrate throughout the album, I get multiple folders for each bitrate. Anything I can do to prevent this aside form changing my naming convention?
I have run across tracks where the year is different for each track, thus adding to more folder/directories being created. This issue is a bit easier for me to think of a fix on, as I want to copy existing YEAR data and xfer it to the COMMENT field, and then replace the year column with a single year. Any ideas on how to manage this simply?
Thanks for the hand holding on this, thus far. lol i cant help but think about when i dabble in making track listings in html.
You can create a new "Format values" action. As target field use "COMMENT" and as format string use "%year%". After you ran the action over your files, simply change the year value and save the tags.
