Hi ! I need to change this:
(TITLE field) Girl Gone Wide (Live) (Live)
to this:
I don't know what command to use. REPLACE delete both (Live), but I only want the delete one of them.
Thank's in advance !!!
B Garcia
to this:
B Garcia
There sure are more solutions to that but I only mention 2 of them with a simple replace-action:
Field: TITLE
ORIGINAL: (Live) (There is a trailing space after (Live))
Replacement: (Empty)
Field: TITLE
ORIGINAL: (Live) (Live)
Replacement: (Live)
But one question:
Why do you add the Artist (Madonna) in the title-tag?
Do not work
Madonna added by mistake
If the pattern you have supplied in the shape of
(Live) (Live)
is correct, then poster's suggestion should work.
Just to get this clear:
Create an action of the type "Replace", not "Replace with regular expresseion".
Also, the Replace action is case-sensitive, if you tick the corresponding options.
