Need help with expression
I am not very good with building expressions so maybe someone here could help me. I have the following file name....
950 Elvis Presley - Hound Dog.mp3
How do I strip off the "950 " (a space is after the 950)
Also none of the mp3 files have any tag information in them. Can I place the artist and title in the tag somehow from the file name?
I have about 400 songs in this format and would like to do a batch process to convert them all.
Thanks
Dekan
use
^\d+\s{1}
as expression on the _FILENAME field, leave the replacement field empty
explained:
^means at the beginning of the string, \d+ means one or more numbers and \s{1} means exatly one space
and after that u can use filename-tag converter to put the info in the tag %artist% - %title% in ur case
