Need help with “Filename - Tag”
I want to change my Titles to be the same as my Filenames, except without the track numbers that are in the Filenames.
Example-
Filename: 01. Hello and Nice Day
becomes...
Title: Hello and Nice Day
Can someone please explain how to do this?
Try
%dummy%. %title%
Edit the format string to "%dummy% %title%".
That means, everything before the space character will be ignored and everything after will be set as title.
That worked. Thanks!
I used do this in 2 steps, first with Filename - Tag and the Convert tag - tag with $regexp(%title%,\d* ,,) so that the first string consisting of digits followed by a space is converted to nulls.
But your 1-step method is better.
