Need help with regex for ARTISTSORT
#1
Hello,
:book: I have been studying regex syntax today like crazy but cannot figure this one out...
I have my ARTIST tags in the following format:
ArtistFirstName ArtistLastName, AdditionalArtistFirstName AdditionalArtistLastName, etc
I want to create the ARTISTSORT tag with the value as follows:
ArtistLastName, ArtistFirstName; AdditionalArtistLastName, AdditionalArtistFirstName; etc
Typically the ARTIST tag will contain only a single name, but often I have multiple names so ideally the conversion should be able to handle both cases.
Based on this thread Multiple value artist tag to multiple value artistsort I have copied the %artist% tag into the ARTISTSORT tag but am not getting correct results with the replace with regex action.
Any help would be appreciated.
Thanks!
Switching first and last names in fields with multiple artists/soloists
Using rexexp on multiple tag fields
Words Count
Automating Changes to Artist Values
#2
Action type: Replace with regular expression
Field: ARTISTSORT
Regular expression: \s*([^,]+)\s([^,]+)(,|$)
Replace matches with: $2, $1;
#3
Thanks Dano, that works great. How did you figure out what regex to use?
Also I added another action to remove the trailing semi-colon but it is not working, thanks for any corections as I'm still a regex newbie.
Field: ARTISTSORT
Regular expression: ^(.*);$
Replace matches with: $1
OK, even this doesn't work in place of the above
Action type: Format value
Field: ARTISTSORT
Format string: $trimRight(%artistsort%,';')
Weird!
