Need help with Regular Expressions
I am stuck on discogs web result page
I am doing a script and I would like to display the format when it is on a line.
Format always start with "Format: "
findinline "Format: " 1 1
Now I would like to use sayregexp function
I started with something like
sayregexp "[^(...)](?=(...))" ""
but that's bad
I tried something like
sayregexp ".
Because sometimes it is follow by three dots. ...
Sometime it is follow byt 3 dost "..." sometimes it is follow by "<", but other text could be follow with the same signs. Just the first reg result should be display.
I hope somebody could help and I am enough clear. Find attached a source file. The sayregexp is on line 76.discogs_album_ext5.src (11.6 KB)
Thanks for your help
