I have the complete works by Bach *The Bach Edition" and wish to add the CD Volume and Disc Number into the Album title i.e.
Current Album Title
Bach Edition: Masses BWV 233 & 234
Current CD Number
V-03
I want to make the Album name as follows:-
Bach Edition V-03: Masses BWV 233 & 234
It is easy enough to do on a CD by CD basis...there are 155 of them.
Is there a way of putting the vale of another field into the "Replace With:" expression?
TIA
OK...worked out a solution but it is not elegant
- Export the Album and the CD Number tag to a csv file
- Open csv file in Excel and with a couple of formulas insert the CD Number into the middle of the Album name string
- Sort the column on CD NUmber
- Save the resultant column as a text file
- Back in mp3tag convert text file to tag for Album name ensuring that sort on CD Number has been done first...
- Wait a few minutes as all 3000 tracks are done
HOWEVER
It would be nice ot be able to refer to other tags within the replace action
dano
3
You could use "Format value" action with $replace(%album%,Bach Edition,Bach Edition %discnumber%)
