Beluna
1
Has anyone created a tool or know of a tool to find and delete www address I hve in my folders.
Someone created this tool that works perfect in finding albumart work and deleting them in a batch.
cd %1
attrib -h -s . /s
del /s albumart*.jpg
del /s desktop.ini
I want something similar to find webadress in my folders i no longer need.
www.microsoftmusic.com
http://www.blogs.com
www.amazon.com
Thanks
you could shorten the time by one cycle if you leave out the "attrib" command and use
del /s /as /ah albumart*.jpg
If you want to find the files then use the command shell and the command(s)
dir /s www*
dir /s http*
This will show the occurances.
If you want to delete the files straight away use
del /s www*
del /s http*
Beluna
3
Didn't work, but i think the problem could be it's shortcuts to the web address that's trying to delete
Doesn't really help.
If I have a link to an address, it has the extension .lnk
So perhaps you check one of the links and see what the actual extension is and then delete these.
