New feature: Progress indicator
I'm fequently working with my entire library (> 130K tracks).
I can't tell when a filter is done working. Mp3Tag says "Ready" at the bottom even though the page isn't displaying the results of the current filter.
The same applies to Undo. I have to click on the scrollbar every so often to see if the undo is complete.
Apparently it is not so simple: https://www.youtube.com/watch?v=CvkOWb1U-LI
But an overall indicator telling the user that a process is being still being performed would be a nice addition to the software
I don't need to know quantitative progress. I just want to know whether it's still processing my filter or undo whether it's done
Just a "Working..." or similar indicator in the bottom of the filter bar, and "Ready" when done would be great.
I've just noticed this topic and just for reference, wanted to add that with Mp3tag v3.07a I've
[2021-06-21] NEW: added status bar indicator for long-running filtering operations.
The undo operation shows a progress dialog (and taskbar progress) and displays an undo text in the status bar.
