Looking at actual mp3 files, I can see id3v2 identifier (ID3) and ID3v2 version, but I cannot understand id3v2 flags and size, especially %abcd0000 and 4 *%0xxxxxxx part.
Mp3tag has placeholders for tag sizes you can use in the columns:
$div(%_tag_size%,1024)kb (%_tag_size_prepended%/%_tag_size_appended%)
ID3v2.4 Info:
You should read these parts closely from id3v2.4.0-structure.txt:
2. Conventions in this document
3.1. ID3v2 header
6.2. Synchsafe integers
A small example (I hope it's correct)
Header:
$49 $44 $33 | $04 $00 | $80 | $00 $00 $10 $77
Decode Flag Byte: (from hex to binary)
$80 -> %10000000 : Bit a - Unsynchronisation
Decode Tag size Bytes:
$10 $77 - > %1000001110111
10000 | 01110111 : remove Bit 7
1000 | 01110111
%100001110111 -> 2167
Tag size: 2167 Bytes
ID3v2.4 Info:
3.1. ID3v2 header
Header:
1000 | 01110111
Tag size: 2167 Bytes<!--QuoteEnd--></div><!--QuoteEEnd-->
Sorry for bumping an old post. But you are a life saver! Thank you so much for this. It helped a lot. I wish you could rep people on this forum.
