Can I make an action that will write tags album from the parent dir
for example: I have dir Rammstein and subdirectories with album names : Mutter, Rosenrot... and the action should take the the dir name and put it into the artist tag
I hope you understand me
Thx
never mind i found a way to do this:
Action type: Format value
Field: ALBUM
Formatstring: %_directory%
