no 1 track no tag data
Hi confused
when i use Freedb to get tag data, mp3tag doesnot collect any data for track 1, but all the other tracks are okay
many thanks
Please try if you can edit track one manually - I've just tested the remote freedb function and everything works fine.
Yes just tried and it will take the data manually
Does this happen on all albums? Which freedb method are you using?
Thanks!
~ Florian
Florian
i was using get data from files, i think it must have been me or a glich with the two cds i was tagging as it has been okay since.
many thanks
