No full customizations for toolbar yet?
I am still waiting for that version that can make my icons and my bars have the size and the colors of my preferences, and even that option to "add or remove" icons, but I now believe this will be not possible with the new bars and menus. Am I right?
PS: The lyrics section is still an unripe implementation, according to my point of view. I could be wrong though.
New and Delete are both possible options if you customize the toolbar with a current Mp3tag version:
You can also customize icons for single toolbar items:
The toolbar size can currently be set to one of these values:
Hello, @jamm2005us,
We can manage two custom Toolbars with tooltip support, starting with version
I believe: mp3tag-v3.34-beta.9-x64-setup.exe
Click on View in the top left corner.
Then click on Toolbar.
You can choose:
Customize main toolbar – Opens the first toolbar with the existing Mp3tag icons.
Customize custom toolbar – Creates a second toolbar…
In the custom toolbar programming, Florian added this very useful command:
  • You can use the keyboard shortcut: CTRL+D, to remove all brackets from the icons.
  • You can use the keyboard shortcut: CTRL+E, to add all brackets to the icons.
