No system sound in 3.04 which was in 2.99
hi,
i updated my 2.99 release to 3.04.
this feature is missing now :
when i saved, there is no more sound (basic windows sound i guess).
i use Win7 x64, maybe you canceled this feature due to end of support ?
sir, thank you for your reply.
Best regards
ok
i discovered i had to activate the notification message to hear the sound...
it is a "pin in the ass" because, before i could save and go to other application in my workflow and use my ear to know all is ok.
Now i have to wait the end of the save operation and clic another button !
You should add another option in the message window :
:white_check_mark: Ear a default window sound system
and another better option :
:ballot_box_with_check: desable the notification when all item of total are saved, just play the sound and release the instance and the focus to system
other sound notification is disappear :
when you use rename by tag from toolbar (tag-->filename).
no sound complete anymore... :sob:
As you wrote above you know how to change that in the options.
So why don't you just do it and all is like you are used to?
