Hello everybody,
I want to remove (Live) in this expression "01 - The Thrill Is Gone (Live)"
This action does'nt work properly, why?
Regular Express: "FILENAME": "$num(%track%,2) - $regexp(%title%, (Live),)" -> ""
Windows 7 with Mp3tag v3.11
Thanks for your help!
... because that what you entered has hardly anything to do with regular expressions?
If you want to fiddle with the filename only, then try Converter>Filename-Filename
Mask over source: %1 (Live)
Target: %1
If you insist on an action, try a simple replace
Search: (Live)
Replace with:
