If I select several files to tag as a group, the fields on the left panel do not default to .
This is a huge problem when trying to correct album tags, as there is a strong likelihood when tagging large numbers of files, that I'll overwrite tags accidentally.
I've checked the defaults for tags, and they are set to but when I select several files, it displays all of the information for the first one on the list, and will overwrite all of the tags with that file's information if I save at that point.
Its been a long time since I've used mp3tag, and I don't remember this behaviour in the past.
Is this a 2.38 bug, or has mp3tag always worked this way?
ADDL:
Upon further investigation, this problem is related to using the shift key to select multiple files. The defaults are fine if files are selected with the ctrl-key. Still a major pain, but at least there's a workaround.
