Not so newbie questions...
#1
Hi everyone! 0/
I'm a fan of this program for years and recently i'm using the latest program. I would like t congratulate all the staff who made it possible for being such a great tool. I have a few doubts though:
  • How can i convert ID3v1 data to ID3v2?
  • How can i convert undescores in spaces in the filename and/or tags?
  • Is it possible to rename the folder where the album is? How?
Sorry to bother, but i really can't find how to do this, i hope you understand... :frowning:
Well, thanks in advance, i'll be waiting for a reply, see you then! :slight_smile:
#2
Please read the FAQs. :slight_smile:
How do I transfer tag information from one tag format to the other?
How do I replace the string "xyz" in tag-fields or filenames?
/t/2395/1
#3
Hey!
Thanks for the pacience, now i can do almost everything that i want with the program! :slight_smile:
Just one more question: is it possible to move folders with actions or commands?
:slight_smile:
Take care! [ ]
#4
You can move the files to another folder and then delete the empty directories.
