If I use this code don't work:
$num(%_counter%,$len(%_total_files%))
I have this in track tag:
1
2
3
I want get this:
01
02
03
If I use the code I get this:
1
2
3
can you solve it?
thank you for your program!
1
2
3
I want get this:
01
02
03
1
2
3
can you solve it?
You have to make sure that %_total_files% is filled (is it? Where do you get the value?).
It may be simpler to just set a fixed number for the padding like "3". This will cater for 999 files.
And I do not think that this is a BUG but simply a request for support.
