According to Docs ( Scripting Functions – Mp3tag Documentation ),
"returns string x interpreted as decimal number, padded with leading zeros from the left up to y digits. It ignores anything from the first non-numeric character, or results in 0 if the string is not numeric."
$num(x,y) should handle decimal numbers, but instead, it truncates the number to the whole value.
Integer arithmetic only, operations support up to 64 arguments.
In that context $num() works as described: it ignores anything from the first non-numeric character onwards which is the dot in your your example. That leaves only the "1" which is then padded to show 2 digits.
Agreed. While I would (obviously) like decimals to be handled, If this is not going to make the priority list, I would suggest changing the docs: "decimal" -> "integer", to avoid confusion.
Thanks @ohrenkino . I updated your suggestion to also handle whole numbers: $ifgreater($strchr(%series-part%,.),0,$num($div($replace(%series-part%,.,),10),2).$mod($replace(%series-part%,.,),10),$num(%series-part%,2))
