Odd Assign Track Number Behavior
This happened will tagging track numbers on mp4 files using the Mac edition of MP3Tag.
Some track numbers are padded with an extra 0 (desired) anothers do not have the zero padding, see video clip that captured the behavior
Rob
Are all of these mp4? Usually any m4v/mp4 will not get leading zeros.
Forgot to mention, these are MP4 files. I'm not sure why MP4 files would be processed differently than MP3 unless metadata specification for the track field is different between the two file types. This certainly doesn't explain why some files were tagged in a different track number format.
m4v and m4a metadata for the track number is expected to be an integer, and as such leading zeros are dropped. The mp3 format is using a string to store the information and can have leading zeros as well as the "/" total discs even.
But it is more odd if all of those files are the same format and yield different results.
