Is there a way of correcting the Irish surname commonality, so, for example, changing O'dowd to O'Dowd?
Many thanks,
FM
This maybe helps !
howdy flyingmale,
this will do it from in the actions dialog ...
field = _TITLE
regex = (C|D|L|O)'(.{1})
replace matches with = $1'$upper($2)
you can replace the c,d,l,o with whatever letters you want or remove all but the "o". it tests for a specific letter followed an apostrophe and at least one letter.
so that ...
L'orange = L'Orange
O'dell = O'Dell
D'meer = D'Meer
C'tahr = C'Tahr
take care,
lee
Thanks so much, Lee, that works great!
FM
howdy flyingmale,
you are quite welcome! glad to help a little now and then ... [grin]
take care,
lee
I've now worked out a new edit of this for Mac.. and Mc... ?
regex = (Mac)(.{1})
replace matches with = $1$upper($2)
regex = (Mc)(.{1})
Great!
Thanks again
FM
howdy flyingmale,
i don't understand what you are trying to do ... please show an example.
here are two that i use for Mac & Mc ...
field = _TAG
regex = (^|\s|(|[|')Mac([bdfgln])
replace matches = $1Mac$upper($2)
the above finds any "Mac" that is at the beginning of a word by testing for ...
- at the beginning of the field
- after a space
- after a (
- after a [
- after a '
... and then followed by any of b-d-f-g-l-n.
other than an "a", these are the only letters i have ever seen in a "mac-whatever" name. i left out the "a" [MacArthur] since i have a surprising number of artists and titles with "maca" at the beginning of the word. really odd, that. [grin] you may want to include the "a" if your listing has more MacNames that cap the "a".
then it upper cases the letter after the "c".
Macdonald = MacDonald
Macleod = MacLeod
this one does the same beginning-of-word test and then upper cases anything after the Mc.
field = _TAG
regex = (^|\s|(|[|')Mc(.{1})
replace matches = $1Mc$upper($2)
Mcleod = McLeod
Mcduff = McDuff
is that what you are looking for?
take care,
lee
It looks like all those problems have been solved already, see also ...
Zoofield
Regular Expressions
yog-sothoth
Case conversion...
... only to pick two guys out of the crowd of forum contributors.
DD.20130211.1322.CET
howdy DetlevD,
thank you for those links! [grin] i knew i got those regexes from here but could not remember who from.
the OP edited his Mac/Mc post so that it no longer matches up with my response. [grin] makes for a rather weird read, now.
take care,
lee
