Omit Track Number from Filename>Title
Hi All,
First post so please help.
I'm trying to find a simple way to create title information from the filename. When I use the automated tool it (obviously) also picks up the full filename;
01-Song Name.mp3 (becomes) 01-Song Name.
Is there a string I'm missing to omit/ignore the first 3 letters/digits when converting? I did see a %dummy% string but no further info.
Any help greatly appreciated.
Fantastic tool by the way, very easy to use and very dependable - well done!
Hello PalatialDave and welcome to Mp3tag,
you can split such filenames into two parts at the hypen separator using the "Filename - Tag" converter with the Formatstring:
%TRACK%-%TITLE%
The converter will set the tag field TRACK to the value of %TRACK% and the tag field TITLE to the value of %TITLE%.
If you do not need the track number to be stored in its own tag field, then use this Fomatstring:
%DUMMY%-%TITLE%
The %DUMMY% placeholder can be used at any place where you can think of to suppress a value.
If the Converter is able to evaluate the given Formatstring, then the dialog will display a preview of the created tag fields in spe.
DD.20100525.1855.CEST
DetlevD
You are a true Gent!
I had been manually selecting and then manually deleting the first three digits of the track name. This tip works an absolute treat.
Thanks very much for your prompt reply - puts real faith into forums like this.
Thanks again - and I would like to also congratulate the team on a cracking little piece of software.
Warmest regards
