Hi, i heard Mp3tag recommended on a posting somewhere and thought i would check it out.
One of the things i want the most is easy album art finding/embedding, that is something like:
click find album art -> it suggests some pix -> you select the best suggestion -> it embeds the art into the file (or group of files).
Does Mp3tag do this? or are there plans for this in the future?
Cheers
-Gaiko
