One-click distribution of a name to two tags
Hello,
My files are all under the following model: "Artist - Title.mp3"
How can I simultaneously tag the name of the artist in the "artist tag" AND in the "albumartist tag" AND the title in the "title tag" using the Filename => tag command?
I naively tried %artist\albumartist% - %title% but it doesn't work. Do you have a formula that works in one clic?
Paul
TO get the same info twice you have to copy it or create a copy.
The easiest way would be to import the data into just artist and title fields and then copy artist to albumartist in 1 go with an action as described in the FAQs:
Anything more fancy like an action of the type "Guess value" that does the duplication and splitting with a single action removes the discrete charme of being able to adapt the import mask with the help of a preview.
